Problem when using H9 with Line 6 Helix
Home › Forums › Products › Stompboxes › Problem when using H9 with Line 6 Helix
Viewing 4 reply threads
    • #150183
        Hi Tim
        For obvious reasosn, I am not familiar with the Line6 Helix, so hopefully you will forgive my ignorance.
        But, what do you mean by a "patch cable" ?
        How is it connected, and what is its purpose ?
      • #150184
        Hi Nick,
        I have the Helix and H9 connected by a regular midi cable. Purpose is that I want to use the helix to control the H9 – send program changes, activate, parameters, et cetera and integrate this in the Helix as such.
        So, I connect it via midi – much like this guy ( ) – and connect the H9 to one of the FX loops on the helix. However, as soon as I connect the 6.3 monojack cables from the Helix send 1 to the H9’s mono in, the H9 stops listening to program changes.
        Does that clarify my issue?
      • #114969
        Hi all,
        I have a very strange issue with controlling my Eventide H9 with my Line 6 Helix. Everything is set-up properly in both the H9 Control app and on the Helix; as long as there is just a midi cable connecting both devices, I can give all the messages required.
        However, the moment I connect a patch cable from the H9 to the Helix, the H9 stops following  Midi commands sent by the Helix. Take the cable out, and it starts working again.
        I have ruled out groundloops – tried insulated power supplies, other wallwarts, et cetera – or other such matters, and am truly lost at what to truy next. Did any of you encounter this and have any idea what could cause this behavior?
        Best,
        Tim
      • #150279
        camn
          Is this a dynamic thing, or is it the same if you cold boot your Helix and h9 with the cables all already connected?
        • #150282
            I'm thinking that you have a bad cable or a bad socket such that one side of the MIDI is connecting to ground on the H9, and when you connect your jacks, this shorts it out.
            First step – try different MIDI cables.
