Problem with expression pedal, what can i do?
Home Forums Products Stompboxes Problem with expression pedal, what can i do?
    • #111816
      zabala
        Hi, a just bought a pigtronix dual expression pedal and i conected it to my eventide , for control some parametrers but the level change like this way: 0 (Down) -100(Middle)-0 (up).
        I want that this change be  from 0 (Down) to 100(Up) , not 0 (Down) -100(Middle)-0 (up).
        I don´t know what´s the problem, maybe could be the expression pedal buy i saw some videos about this pedal which shows the change of parametrers like this: 0 (Down) to 100(Up).
        Thanks.
      • #126410
          This is a common problem – your pedal is wired as a volume control and expects a TRS connection, as stated in its manual. Don't know why they do this. You are probably using a mono (TS) jack.
          The solution is to use a TRS (stereo) cable.
