Home › Forums › Products › Stompboxes › Question: How to setup H9 with PC audio interface (iConnectAudio4+) ?
May 14, 2019 at 2:39 pm #115313
Hi, I want to use my H9 as an external audio effect in my Daw via my audio interface, but I don’t know how.
I am thinking about connecting the 2 x output to 2 x inputs etc, but my worry is that a terrible audio loop will happen, I mean the audio goes from PC to Output Audio Interface to H9 to input AI to Pc to output etc, etc, it wil never stop, is my worry.
Is possible what I want, and if so : how?
My gear:
Daw : Studio One Pro
Audio Interface: iConnectivity iConnectAudio4+
PC: Windows 10
H9 Max -
May 14, 2019 at 6:19 pm #151890Marcel wrote:Hi, I want to use my H9 as an external audio effect in my Daw via my audio interface, but I don’t know how. I am thinking about connecting the 2 x output to 2 x inputs etc, but my worry is that a terrible audio loop will happen, I mean the audio goes from PC to Output Audio Interface to H9 to input AI to Pc to output etc, etc, it wil never stop, is my worry. Is possible what I want, and if so : how? My gear: Daw : Studio One Pro Audio Interface: iConnectivity iConnectAudio4+ PC: Windows 10 H9 Max
Yes it is possible. The audio coming from your interface into your PC won't go to the interface again (except you set that intentionally).
May 14, 2019 at 10:29 pm #151892
That is great news. Thanks!!
May 16, 2019 at 12:39 pm #151901
Hmmm…..I have tried a lot of things, but I couldn’t make it work.
What did work was: Keyboard audio > H9 > Audio Interface > PC Daw.
No problem there, I did get a wet audio signal.But what I want, didn’t work, which is : Daw audio > interface > H9 > interface > Daw wet audio.
Perhaps I should contact the iConnectivity forum.
May 16, 2019 at 4:38 pm #151904Marcel wrote:Hmmm…..I have tried a lot of things, but I couldn’t make it work. What did work was: Keyboard audio > H9 > Audio Interface > PC Daw. No problem there, I did get a wet audio signal. But what I want, didn’t work, which is : Daw audio > interface > H9 > interface > Daw wet audio. Perhaps I should contact the iConnectivity forum.
Yes. I believe iConnectivity can help you more on this. You need to do most settings in your DAW. Set the track that you want to apply H9's effects to iConnectivity's output, and record iConnectivity's input on a new track.
iConnectivity's output -> H9's input
H9's output -> iConnectivity's input
