Question on effect type.
Home Forums Products Vsig and Preset Development Question on effect type.
    • #105703
      razo1
      I am just starting out learning to program my Eventide Orville and heard this effect. The clip is from the 80's group Propaganda: I was wondering what type of effect has been applied to the vocals in this short clip, if anyone could have a listen?
      And possibly give some hints on what Eventide effects blocs that can be used to construct it?
      The file is here (Wav format): http://www.mediafire.com/?evjy0n2eu91
      Thanks in advance,
      Ole
    • #117605
      IDeangelis
       Hi Ole
      the effect is not just..an effect! It's a complex aggregation of different fx that will require a lot of different testing possibilities.
      I hear:
      -panning delay
      -hi amount of diffusion
      -flanging
      -reverb
      -possibly eq/filtering of some kind
      there are many ways these effects can be built and  the unit's presets are the learning tools.
      For panning delay try lfo modulating 2 ampmods in opposite pattern, fed by a delay w/mix for feedback.
      Diffusor: try using 4 voice at least. Don't use gains higher than -/+ 0.5.
      Flanging : moddelay or microdelay with mix for feedback. Modulated by an Lfo.
      Reverb : a Reverb C would be enough here.
      Tweaking required!
      cheers
