Rear rail support?
Home › Forums › Products › Rackmount › Rear rail support?
    • #107244
      sean.e
        Does the H8000 support attachment of rear rail support brackets like these?
        http://www.audiopile.net/products/Cases/SRD_Rack_Drawers/Rear_Support_Brackets/Rear_Support_Bracket_Drop_cutsheet.shtml
        If not, what other rack hardware is available for rear support?
      • #120720
          We have no experience of these – maybe our other users have.
          I've always used a 2×4 and some wood screws ….
        • #120897
          I can be certain rear support tabs are not provided on neither my 7000 or 4000B. You could "carefully" drill a hole on each rear side and install a bolt from inside acting as a stud to attach some custom metal brackets. I have yet to drill my units, I'd recommend taping everything up to avoid ANY metal shavings from entering your Eventide.
          This way you can unbolt the rear for later removal of unit.
          The only pre-made rear support I found bolted to front and rear rails, weighed around 13 lbs., and cost around $150 from a computer data systems store.
