Request/Question – select input on a system level
Home Forums Products Stompboxes Request/Question – select input on a system level
Viewing 0 reply threads
    • #168374
      actionmusicuk
        Fantastic pedal, congratulations!
        I’m using it in a studio and it’s wired up to a patchbay. the way inserts work on the pedal is fantastic, I can make the h90 a central part of my old effects and connect via inserts to the DAW.
        Could we have a way of choosing input on a system level, at the moment sometimes I have a synth stereo in, all fine, but if I have a mono synth I either have to take out input jack two or multiple it to both 1+2 inputs – as on certain stereo programs you get the dry on one side. Similarly if I plug the guitar into the patchy I need to remove the other jack as can’t multi that signal in the same way as synths. would be great if you could set input one (or another) as a system preference and every patch would react as if that was the source at 1+2.
