June 26, 2011 at 7:45 am #107967
Following some interresting thread on HRI about how to make reverberation with plex and diffusors, I have tried to program one based on Italo algorithm.
Here is the result I would like to share.
First a copy of the info page i have included so that you can see what it is about:
Reverberation-like
sound inspired by some plex based algorithm example from Italo. Master
controls all plex and diffusors feedbacks from min to max values, which
are configurables. Diff. controls diffusion from min at 0 up to max at
60 and also activates input cross fade into 2 modulated diffusors before
the plex from min at 40 up to max 100. Detune controls stereo detuning
at the output additionnaly with depth of input modulated diffusors. Thus
detune setting is impacted by diffs. settings above 40, and vice
versa. Wet/Dry mix is consigurable if needed. Also an EQ is available.
HighCut is always active, low/high param EQ can be switched ON/OFF.
Though those basic parameters are enough to achieve many different
sounds, additional tweaking can be done. In the core plex 6 simple
diffusors are used along with 2 modulated diffusors. Diffusors delays
are configurable: for simple diffusors only offset is available (then
delays are configured as increments by 1 from this offset). 2 modulated
diffusors are also used with offset setting as well as a multiplier
setting which allow longer delays into those diffusors. delay n value
=(offset+n)*mult in ms. Modulations are also configurable for those 2
modulated diffusors, enabling at lower settings some flanging effects
for instance. Play with them and listen ! Ext 5 controls Master. Summed
in, stereo out. I hope you will enjoy this preset. Thanks Italo for
helping to learn how to take the best from those awesome machines
Here is the preset in sif mod. under this link:
http://laurent.franenberg.free.fr/H8000 … dVerb7.sifAnd also in text mod (.sig):
HEADM
adc 2 2 crossin2-out crossin1-out ItaloInspiredVerb Empty 5
MasterVerb-obj tone_m-obj diffusors_m-obj DiffMod-obj info-obj
;=175,175,100,0
DIFFUSOR diffusor1 4 plex-out2 c_multiply17-out 1
c_graph-out1 c_graph-out2 c_graph-out3 c_graph-out4 c_adder3-out
c_adder3-out c_adder3-out c_adder3-out ;=1925,425,100,0
DIFFUSOR
diffusor2 4 plex-out3 c_multiply17-out 1 c_graph-out5 c_graph-out6
c_graph-out7 c_graph-out8 c_adder3-out c_adder3-out c_adder3-out
c_adder3-out ;=2075,575,100,0
DIFFUSOR diffusor3 4 plex-out4
c_multiply17-out 1 c_graph-out9 c_graph-out10 c_graph-out11
c_graph-out12 c_adder3-out c_adder3-out c_adder3-out c_adder3-out
;=1925,750,100,0
DIFFUSOR diffusor4 4 plex-out5 c_multiply17-out 1
c_graph-out13 c_graph-out14 c_graph-out15 c_graph-out16 c_adder3-out
c_adder3-out c_adder3-out c_adder3-out ;=2075,875,100,0
DIFFUSOR
diffusor5 4 plex-out6 c_multiply17-out 1 c_graph-out17 c_graph-out18
c_graph-out19 c_graph-out20 c_adder3-out c_adder3-out c_adder3-out
c_adder3-out ;=1925,1075,100,0
DIFFUSOR diffusor6 4 plex-out7
c_multiply17-out 1 c_graph-out21 c_graph-out22 c_graph-out23
c_graph-out24 c_adder3-out c_adder3-out c_adder3-out c_adder3-out
;=2075,1200,100,0
PLEX plex 8 crossin-out c_adder2-out
diffchor_in-out diffusor1-out diffusor2-out diffusor3-out diffusor4-out
diffusor5-out diffusor6-out diffchor_out-out ;=2175,200,100,0
DIFFCHORUS
diffchor_in 8 plex-out1 c_multiply17-out dsize_k-out moddepth_k-out
modrate_k-out modratespan_k-out gliderate_k-out mult_diffchr_in-out
mult_diffchr_in1-out mult_diffchr_in2-out mult_diffchr_in3-out
mult_diffchr_in4-out mult_diffchr_in5-out mult_diffchr_in6-out
mult_diffchr_in7-out c_adder4-out c_adder4-out c_adder4-out c_adder4-out
c_adder4-out c_adder4-out c_adder4-out c_adder4-out ;=1125,350,100,0
HIGHCUT "highcut L" detune-out highcut_k-out ;=2475,200,100,0
HIGHCUT "highcut R" detune1-out highcut_k-out ;=2475,325,100,0
TONE "EQ L" "highcut L-out" low_freq_k-out low_level_k-out high_freq_k-out high_level_k-out ;=2625,200,100,0
TONE "EQ R" "highcut R-out" low_freq_k-out low_level_k-out high_freq_k-out high_level_k-out ;=2625,425,100,0
ISWITCH "EQ L Bypass" 2 EQ_k-out "EQ L-out" "highcut L-out" ;=2750,200,100,0
ISWITCH "EQ R bypass" 2 EQ_k-out "EQ R-out" "highcut R-out" ;=2750,300,100,0
STEREOMIXER stereomixer 2 "EQ L Bypass-out" "EQ R bypass-out" -3 -3 -1 1 ;=2875,250,100,0
MIXER sum 2 adc-in1 adc-in2 -6 -6 ;=125,100,100,0
CROSSIN crossin sum-out diffchor_out~2-out c_to_a-out ;=1025,100,100,0
CROSSIN crossin1 adc-in2 stereomixer-right c_to_a_wetdry-out ;=2875,150,100,0
C_TO_A c_to_a_wetdry c_multiply22-out ;=2675,50,100,0
CROSSIN crossin2 adc-in1 stereomixer-left c_to_a_wetdry-out ;=2875,25,100,0
C_TO_A c_to_a c_multiply21-out ;=925,250,100,0
MENUPAGE
tone_m EQ EQ 8 highcut_k-obj dummy-obj dummy-obj EQ_k-obj
low_freq_k-obj low_level_k-obj high_freq_k-obj high_level_k-obj
;=2625,625,100,0
MENUPAGE diffusors_m "Diffusors settings" Delays 8
k_diff_dlayoffset-obj dummy-obj dummy-obj dummy-obj k_diff_in_off-obj
k_diffinmult-obj k_diff_out_off-obj k_diffoutmult-obj ;=1750,1425,100,0
C_GRAPH
c_graph 2 0 0 0 0 24 0 2000 1 k_diff_dlayoffset-out 0 1 2 3 4 5 6 7 8 9
10 11 12 13 14 15 16 17 18 19 20 21 22 23 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 ;=1750,625,100,0
KNOB k_diff_dlayoffset "Delays Offset:%1.0fms" dfdlof 0 1976 1 40 ;=1550,900,100,0
KNOB k_diff_in_off "ModDly1 Offset:%1.0fms" difinoff 0 456 1 0 ;=750,350,100,0
C_MULTIPLY mult_diffchr_in c_graph_in-out1 k_diffinmult-out ;=875,450,100,0
C_MULTIPLY mult_diffchr_in1 c_graph_in-out2 k_diffinmult-out ;=875,575,100,0
C_MULTIPLY mult_diffchr_in2 c_graph_in-out3 k_diffinmult-out ;=875,700,100,0
C_MULTIPLY mult_diffchr_in3 c_graph_in-out4 k_diffinmult-out ;=875,825,100,0
C_MULTIPLY mult_diffchr_in4 c_graph_in-out5 k_diffinmult-out ;=1000,500,100,0
C_MULTIPLY mult_diffchr_in5 c_graph_in-out6 k_diffinmult-out ;=1000,625,100,0
C_MULTIPLY mult_diffchr_in6 c_graph_in-out7 0 ;=1000,750,100,0
C_MULTIPLY mult_diffchr_in7 c_graph_in-out8 k_diffinmult-out ;=1000,875,100,0
C_GRAPH c_graph_in 2 0 0 0 0 8 0 500 1 k_diff_in_off-out 0 1 2 3 4 5 6 7 0 0 0 0 0 0 0 0 ;=750,475,100,0
KNOB k_diffinmult "ModDly1 Mult: %2.1f" difinmult 0 10 0.1 1.5 ;=750,800,100,0
KNOB dsize_k "Size1: %5.2f" size 0 1 0.01 0.02 ;=1275,550,100,0
KNOB moddepth_k "Depth1: %4.2f ms" depth 0 100 1 5 ;=1275,625,100,0
KNOB modrate_k "Rate1: %5.2f ms/sec" rate 0 100 0.01 0.01 ;=1275,700,100,0
KNOB gliderate_k "Glide1: %4.2f" difinmult 0 1 0.01 0.09 ;=1275,800,100,0
KNOB dsize_k1 "Size2: %5.2f" size 0 1 0.01 1 ;=1275,1025,100,0
KNOB moddepth_k1 "Depth2: %4.2f ms" depth 0 100 1 5 ;=1275,1100,100,0
KNOB gliderate_k1 "Rate2: %5.2f ms/sec" rate 0 1 0.01 0.03 ;=1275,1175,100,0
KNOB gliderate_k2 "Glide2: %4.2f" difinmult 0 1 0.01 1 ;=1275,1275,100,0
KNOB modratespan_k span span 0 1 1 1 ;=1125,950,100,0
KNOB highcut_k "high cut: %5.0f Hz" HighCut 0 20000 10 2200 ;=2375,475,100,0
KNOB low_freq_k " low freq: %5.0f Hz" lowfreq 0 20000 10 1000 ;=2775,550,100,0
KNOB low_level_k " low gain:%6.0f db" lowlevel -18 18 1 6 ;=2775,650,100,0
KNOB high_level_k "high gain:%6.0f db" highlevel -18 18 1 -4 ;=2900,650,100,0
KNOB high_freq_k "high freq: %5.0f Hz" highfreq 20 20000 10 1600 ;=2900,550,100,0
DIFFCHORUS
diffchor_out 8 plex-out8 c_multiply17-out dsize_k1-out moddepth_k1-out
0.03 modratespan_k-out gliderate_k2-out mult_diffchr_out-out
mult_diffchr_out1-out mult_diffchr_out2-out mult_diffchr_out3-out
mult_diffchr_out5-out mult_diffchr_out4-out mult_diffchr_out6-out
mult_diffchr_out7-out c_adder4-out c_adder4-out c_adder4-out
c_adder4-out c_adder4-out c_adder4-out c_adder4-out c_adder4-out
;=1125,1075,100,0
KNOB k_diff_out_off "ModDly2 Offset:%0.0f ms" difinoff 0 456 1 10 ;=750,1075,100,0
C_MULTIPLY mult_diffchr_out c_graph_out-out1 k_diffoutmult-out ;=875,1000,100,0
C_MULTIPLY mult_diffchr_out1 c_graph_out-out2 k_diffoutmult-out ;=875,1100,100,0
C_MULTIPLY mult_diffchr_out2 c_graph_out-out3 k_diffoutmult-out ;=875,1200,100,0
C_MULTIPLY mult_diffchr_out3 c_graph_out-out4 k_diffoutmult-out ;=875,1300,100,0
C_MULTIPLY mult_diffchr_out4 c_graph_out-out6 k_diffoutmult-out ;=1000,1275,100,0
C_MULTIPLY mult_diffchr_out5 c_graph_out-out5 k_diffoutmult-out ;=1000,1175,100,0
C_MULTIPLY mult_diffchr_out6 c_graph_out-out7 k_diffoutmult-out ;=1000,1375,100,0
C_MULTIPLY mult_diffchr_out7 c_graph_out-out8 k_diffoutmult-out ;=1000,1475,100,0
C_GRAPH c_graph_out 2 0 0 0 0 8 0 500 1 k_diff_out_off-out 0 1 2 3 4 5 6 7 0 0 0 0 0 0 0 0 ;=750,1175,100,0
KNOB k_diffoutmult "ModDly2 Mult: %2.1f" difinmul 0 10 0.1 1.4998 ;=750,1450,100,0
MENUPAGE diffchorout_m Diffchrout dfchout 1 diffchor_out-obj ;=1300,1400,100,0
MENUPAGE
DiffMod "Diffusors Mod" Mod 8 dsize_k-obj moddepth_k-obj modrate_k-obj
gliderate_k-obj dsize_k1-obj moddepth_k1-obj gliderate_k1-obj
gliderate_k2-obj ;=1425,850,100,0
TEXTKNOB EQ_k " EQ: %3s ==>" textknob 2 0 ON OFF ;=2375,650,100,0
PERCENTKNOB diffchr_out_fdbk_ "Feedback: %5.0f %%" fdbk 0 100 1 80 ;=100,675,100,0
DIFFCHORUS
diffchor_out~1 8 sum-out 1 1 detune_k-out 0.1 1 1 mult_diffchr_out~-out
mult_diffchr_out11-out mult_diffchr_out21-out mult_diffchr_out31-out
mult_diffchr_out8-out mult_diffchr_out12-out mult_diffchr_out22-out
mult_diffchr_out32-out diffchr_out_fdbk_-out diffchr_out_fdbk_-out
diffchr_out_fdbk_-out diffchr_out_fdbk_-out diffchr_out_fdbk_-out
;=250,300,100,0
KNOB k_diff_out_off~1 "DlyOffset: %4.0f" difinoff 0 456 1 0 ;=100,400,100,0
C_MULTIPLY mult_diffchr_out~ c_graph_out~1-out1 k_diffoutmult~1-out ;=500,300,100,0
C_MULTIPLY mult_diffchr_out11 c_graph_out~1-out2 k_diffoutmult~1-out ;=500,400,100,0
C_MULTIPLY mult_diffchr_out21 c_graph_out~1-out3 k_diffoutmult~1-out ;=500,500,100,0
C_MULTIPLY mult_diffchr_out31 c_graph_out~1-out4 k_diffoutmult~1-out ;=500,600,100,0
C_MULTIPLY mult_diffchr_out8 c_graph_out~1-out5 k_diffoutmult~1-out ;=625,450,100,0
C_MULTIPLY mult_diffchr_out12 c_graph_out~1-out6 k_diffoutmult~1-out ;=625,550,100,0
C_MULTIPLY mult_diffchr_out22 c_graph_out~1-out7 k_diffoutmult~1-out ;=625,650,100,0
C_MULTIPLY mult_diffchr_out32 c_graph_out~1-out8 k_diffoutmult~1-out ;=625,750,100,0
C_GRAPH c_graph_out~1 2 0 0 0 0 8 0 500 1 k_diff_out_off~1-out 0 1 2 3 4 5 6 7 0 0 0 0 0 0 0 0 ;=375,375,100,0
KNOB k_diffoutmult~1 "DlyMult: %6.0f" difinmul 0 100 1 2 ;=100,550,100,0
PERCENTKNOB diffchr_out_fdbk_1 "Feedback: %5.0f %%" fdbk 0 100 1 80 ;=100,1325,100,0
DIFFCHORUS
diffchor_out~2 8 diffchor_out~1-out 1 1 0 0.11 1 1
mult_diffchr_out~1-out mult_diffchr_out13-out mult_diffchr_out23-out
mult_diffchr_out33-out mult_diffchr_out9-out mult_diffchr_out14-out
mult_diffchr_out24-out mult_diffchr_out34-out diffchr_out_fdbk_1-out
diffchr_out_fdbk_1-out diffchr_out_fdbk_1-out diffchr_out_fdbk_1-out
diffchr_out_fdbk_1-out ;=250,950,100,0
KNOB k_diff_out_off~2 "DlyOffset: %4.0f" difinoff 0 456 1 0 ;=100,1050,100,0
C_MULTIPLY mult_diffchr_out~1 c_graph_out~2-out1 k_diffoutmult~2-out ;=500,925,100,0
C_MULTIPLY mult_diffchr_out13 c_graph_out~2-out2 k_diffoutmult~2-out ;=500,1025,100,0
C_MULTIPLY mult_diffchr_out23 c_graph_out~2-out3 k_diffoutmult~2-out ;=500,1125,100,0
C_MULTIPLY mult_diffchr_out33 c_graph_out~2-out4 k_diffoutmult~2-out ;=500,1225,100,0
C_MULTIPLY mult_diffchr_out9 c_graph_out~2-out5 k_diffoutmult~2-out ;=625,1100,100,0
C_MULTIPLY mult_diffchr_out14 c_graph_out~2-out6 k_diffoutmult~2-out ;=625,1200,100,0
C_MULTIPLY mult_diffchr_out24 c_graph_out~2-out7 k_diffoutmult~2-out ;=625,1300,100,0
C_MULTIPLY mult_diffchr_out34 c_graph_out~2-out8 k_diffoutmult~2-out ;=625,1400,100,0
C_GRAPH c_graph_out~2 2 0 0 0 0 8 0 500 1 k_diff_out_off~2-out 0 1 2 3 4 5 6 7 0 0 0 0 0 0 0 0 ;=375,1050,100,0
KNOB k_diffoutmult~2 "DlyMult: %6.0f" difinmul 0 100 1 1 ;=100,1200,100,0
EXTCONTROL extcontrol PlexFdbk_ctrl -2048 0 0 0 ;=1375,150,100,0
C_MULTIPLY c_multiply6 extcontrol-out 100 ;=1475,250,100,0
C_MULTIPLY c_multiply22 in1_k1-out 0.01 ;=2525,50,100,0
C_MULTIPLY c_multiply17 c_multiply20-out 0.01 ;=1525,725,100,0
C_MULTIPLY c_multiply19 c_subtract3-out 1.6667 ;=725,100,100,0
C_MULTIPLY c_multiply21 c_multiply19-out 0.01 ;=900,100,100,0
MONITOR m_plexfdbk c_multiply-out "Plex: %11.0f%%" Plexfdbk ;=1600,1400,100,0
C_MULTIPLY c_multiply c_adder2-out 100 ;=1425,1550,100,0
MONITOR m_diff_fdbk c_multiply3-out "Diffusors: %6.0f%%" DiffFdbk ;=1600,1550,100,0
C_MULTIPLY c_multiply3 c_adder3-out 100 ;=1425,1425,100,0
MONITOR m_diff_fdbk1 c_multiply5-out "Mod Diffusors: %2.0f%%" DiffFdbk ;=1400,425,100,0
C_MULTIPLY c_multiply5 c_adder4-out 100 ;=1275,425,100,0
C_MULTIPLY c_multiply1 master_k-out c_multiply13-out ;=1650,400,100,0
C_MULTIPLY c_multiply16 c_multiply18-out -1 ;=2225,575,100,0
C_MULTIPLY c_multiply18 detune_k-out 0.1 ;=2425,825,100,0
C_ADDER c_adder2 2 c_multiply1-out c_multiply7-out ;=1775,400,100,0
C_MULTIPLY c_multiply2 master_k-out c_multiply15-out ;=1525,1175,100,0
C_ADDER c_adder3 2 c_multiply2-out c_multiply9-out ;=1575,1050,100,0
C_MULTIPLY c_multiply4 master_k-out c_multiply14-out ;=1075,225,100,0
C_ADDER c_adder4 2 c_multiply4-out c_multiply8-out ;=1225,225,100,0
SKNOB3 master_k Master%3.0f GenFdbk 3 1 70 master_k-out 0 100 c_merge-out ;=1925,125,100,0
SKNOB3 in1_k1 DryWet%3.0f drywet 3 1 100 in1_k1-out 0 100 0 ;=2350,25,100,0
SKNOB3 in1_k Diff.%3.0f diff 3 1 70 70 0 100 0 ;=1525,450,100,0
C_MERGE c_merge 2 c_multiply6-out master_k-out ;=1775,275,100,0
C_MULTIPLY c_multiply7 plexmin_k-out 0.01 ;=2275,1325,100,0
C_MULTIPLY c_multiply8 diffmodmin_k-out 0.01 ;=2275,1200,100,0
C_MULTIPLY c_multiply9 diffmin_k-out 0.01 ;=2275,1100,100,0
C_MULTIPLY c_multiply10 "max in_k4-out" 0.01 ;=2425,1325,100,0
C_MULTIPLY c_multiply11 "max in_k3-out" 0.01 ;=2425,1200,100,0
C_MULTIPLY c_multiply12 "max in_k2-out" 0.01 ;=2425,1100,100,0
C_MULTIPLY c_multiply13 c_subtract1-out 0.01 ;=2725,1450,100,0
C_MULTIPLY c_multiply14 c_subtract2-out 0.01 ;=2725,1350,100,0
C_MULTIPLY c_multiply15 c_subtract-out 0.01 ;=2725,1250,100,0
MENUPAGE
FeedbacksCfg "Feedback Config" Config 8 plexmin_k-obj dummy-obj
diffmin_k-obj diffmodmin_k-obj "max in_k4-obj" dummy-obj "max in_k2-obj"
"max in_k3-obj" ;=2875,1275,100,0
;"Plex: %5.0f %%" ;=2675,950,100,0"
;"Plex: %5.0f %%" ;=2725,1000,100,0"
TEXTKNOB dummy "" "" 1 0 0 ;=2250,1500,100,0
TEXTKNOB dummy1 "" "" 1 0 0 ;=400,1650,100,0
TEXTBLOCK textblock 1 "FEEDBACKS MONITOR :" ;=2475,1525,100,0
C_SUBTRACT c_subtract c_multiply12-out c_multiply9-out ;=2575,1100,100,0
C_SUBTRACT c_subtract1 c_multiply10-out c_multiply7-out ;=2575,1325,100,0
C_SUBTRACT c_subtract2 c_multiply11-out c_multiply8-out ;=2575,1200,100,0
MENUPAGE
MasterVerb MasterVerb Master 11 master_k-obj in1_k-obj detune_k-obj
in1_k1-obj textblock-obj m_plexfdbk-obj m_diff_fdbk-obj m_diff_fdbk1-obj
master_k-obj FeedbacksCfg-obj extcontrol-obj ;=1950,1450,100,0
SKNOB3 plexmin_k "PlexMin: %5.0f %%" PlexMin 0 1 60 60 0 "max in_k4-out" 0 ;=2775,1050,100,0
SKNOB3 diffmodmin_k "DiffModMin: %2.0f %%" difmodmin 0 1 20 20 0 "max in_k3-out" 0 ;=2775,925,100,0
SKNOB3 diffmin_k "DiffMin: %5.0f %%" DiffMin 0 1 20 20 0 "max in_k2-out" 0 ;=2775,775,100,0
SKNOB3 "max in_k4" "PlexMax: %5.0f %%" PlexMax 0 1 98 98 plexmin_k-out 100 0 ;=2900,1050,100,0
SKNOB3 "max in_k3" "DiffModMax: %2.0f %%" difmodmax 0 1 40 40 diffmodmin_k-out 100 0 ;=2900,925,100,0
SKNOB3 "max in_k2" "DiffMax: %5.0f %%" DiffMax 0 1 40 40 diffmin_k-out 100 0 ;=2900,775,100,0
DETUNE detune 20 plex-out1 0 20 c_multiply16-out ;=2325,150,100,0
DETUNE detune1 20 plex-out8 0 20 c_multiply18-out ;=2325,325,100,0
SKNOB3 detune_k Detune%3.0f detune 3 1 50 50 0 100 0 ;=2250,850,100,0
C_BOUND c_bound in1_k-out 40 100 ;=450,100,100,0
C_SUBTRACT c_subtract3 c_bound-out 40 ;=575,100,100,0
C_MULTIPLY c_multiply20 c_bound1-out 1.6667 ;=1600,600,100,0
C_BOUND c_bound1 in1_k-out 0 60 ;=1450,600,100,0
MENUPAGE
inputdifftweak_m menupage menupage 7 k_diff_out_off~1-obj
k_diffoutmult~1-obj diffchr_out_fdbk_-obj dummy1-obj
k_diff_out_off~2-obj k_diffoutmult~2-obj diffchr_out_fdbk_1-obj
;=475,1450,100,0
TEXTBLOCK info 46 "Reverberation-like sound inspired
by" "some plex based algorithm example" "from Italo." "Master controls
all plex and diffusors" "feedbacks from min to max values," "which are
configurables." "Diff. controls diffusion from min at 0" "up to max at
60 and also activates" "input cross fade into 2 modulated" "diffusors
before the plex from min at" "40 up to max 100." "Detune controls stereo
detuning at the" "output additionnaly with depth of input" "modulated
diffusors. Thus detune" "setting is impacted by diffs. settings " "above
40, and vice versa." "Wet/Dry mix is consigurable if needed." "Also an
EQ is available. HighCut is" "always active, low/high param EQ can" "be
switched ON/OFF." "Though those basic parameters are" "enough to achieve
many different" "sounds, additional tweaking can be" done. "In the core
plex 6 simple diffusors are" "used along with 2 modulated diffusors."
"Diffusors delays are configurable: for" "simple diffusors only offset
is" "available (then delays are configured" "as increments by 1 from
this offset)." "2 modulated diffusors are also used" "with offset
setting as well as a" "multiplier setting which allow longer" "delays
into those diffusors." "delay n value =(offset+n)*mult in ms."
"Modulations are also configurable for" "those 2 modulated diffusors,
enabling" "at lower settings some flanging effects" "for instance. Play
with them and" "listen !" "Ext 5 controls Master." "Summed in, stereo
out." "I hope you will enjoy this preset." "Thanks Italo for helping to
learn how" "to take the best from those awesome " "machines !"
;=2775,425,100,0
TAIL "L. Franenberg"Feel free to send any comment.
Hope you'll enjoy.
Laurent.
June 26, 2011 at 9:56 am #122341
Thanks for sharing the preset with us Luarent, and I look forward to trying it out 🙂
June 27, 2011 at 12:01 am #122344
Thanks for sharing – and learning about Plex-module!
June 27, 2011 at 5:15 pm #133555
thanks for your interrest.
here is an improved version:
– multiplier settings added on plex simple diffusors for delays configuration (as already done for modulated ones). Allows for possibilities to tweak the verb sound.
– detune tweaked to avoid unwanted glitches on some sound sources when highcut is set to high frequancies.[bad links]
Laurent
June 27, 2011 at 5:19 pm #122355
Thanks for your interrest.
– detune tweaked to avoid unwanted glitches on some sound sources when highcut is set to high frequencies.Sif file:
http://laurent.franenberg.free.fr/H8000 … detune.sif
Sig file (text):
http://laurent.franenberg.free.fr/H8000 … detune.sigLaurent
