Rose switches activate the effect on the release
Home › Forums › Products › Stompboxes › Rose switches activate the effect on the release
    • #188599
      ciclosonico
        I have noticed that Rose switches activate the effect at the moment of release and not when pressed, and the same applies in reverse when I want to switch the effect off. Although this may seem relatively important to some, I’d prefer the action to start the instant I press the switch.
        Is it possible to change this in any way?
        Thank you
      • #188679
        joecozzi
          Hello good friend. There isn’t a way to change this behavior. Because Rose footswtiches have some press-and-hold features it was designed to work this way.
        • #188699
          ciclosonico
            Ciao Joe! Thanks for the explanation, then I’ll continue to use it as I’ve always done. It’s certainly not a problem for me, it was just a slight preference.
