Routing App for H8000FW
Home › Forums › Products › Rackmount › Routing App for H8000FW
Viewing 3 reply threads
    • #114179
      I understand the routing configuration setup inside the H8000FW, and I understand the routing app (sort of). What I can’t figure out if how to connect my Mac 10.1.1 to the Eventide with the config below. I also cant tell if I can do this without the app – 8 Ch ADAT into DSPDA, then B, then 8 channels out via ADAT. into Apogee, then Thunderbolt to Logic X.
      My chain is simple : 8 channels analog into Apogee Symphony Mkii, 8 channels ADAT out from Apogee into H8000FW ADAT in. Then the processed 8 channels of ADAT are fed back into Apogee Channels 9-16. Apogee to Mac via Thunderbolt into Logic X
      Would appreciate any help and insight. The manuals are helpful for most aspects but not clear on this. My Macbook Pro has Thunderbolt, USB3.0, HDMI, and SD jacks.
      Cory
    • #146462
        You don't actually say what your problem is.
        I'm going to assume that you are not getting audio, in which case I would suggest that you use factory routing "ADAT A->B".
        Make sure that SETUP/clock is set to ADAT or WC as appropriate.
      • #146463
        Sorry I wasn’t clear.
        a) Without connecting the my Macbook to the Eventide and using the Router App, Can i set up the H8000FW for the following simple chain: ADAT 1-8 into DSPa, then 1-8 from DSPa to DSPb,  then 1-8 to ADAT out – using one of the Presets? Can I avoid dealing with the router app, because while it is awesome control, i dont get some of it, such as……
        b) If I do want to use the Routing App, I’m not clear on how to physically connect my MacBook to the H8000FW; real world jacks, plugs, signal chains. I dont think my Mac DAW will speak backwards through the chain to the Eventide, but all I have are Thunderbolt, USB 3.0 and HDMI jacks on my MacBook Pro with the Routing App.
      • #146471
        I reread your answer a couple times. I just wasnt sure which preset if any fit the bill. I will look at the list for the ADAT A>B
        Thanks
        Cordell
        • #146498
            It's routing preset 12. Also see UM p.27.
