Routing Help – H90
Home › Forums › Products › Stompboxes › Routing Help – H90
    • #188397
      pmakh
        Hello!
        I recently got an H90 and want to incorporate it into my PBC 6X rig. I currently have it after the PBC and before my TL/BS. Is it possible to route it like:
        Comp > DCX Boost > H90 > PBC input 1 > PBC output to H90 > TL > BS
        I basically want my pitch shift to be before the PBC but my regular mod to be after the PBC.
      • #188404
          Congrats on the new H90! Yes, you can setup something like that by following the instructions below: https://cdn.eventideaudio.com/manuals/h90/1.7.5/content/setup/pre-post.html
          It’s not exactly the same, here’s what you’ll need to do differently:
          • H90 output 1 will go to the PBC input.
          • PBC output goes to H90 input 3
          • H90 output 3 goes to TL
          Let me know if you need further instructions.
          • #188405
            pmakh
              Thanks! I’m guessing I’ll need to change routing settings on the H90?
            • #188462
                Correct, you need to change the routing mode to Dual for this set up. There are some clickable text links for how to do that in the section of the manual that I shared.
