Home › Forums › Products › Stompboxes › Saving new algorythems onto the H9
July 11, 2016 at 12:03 pm #113557
Houman
MemberI just purchased the H9 and paired it with my iPad. In the H9 app I bought a new algorythm which I can access only through the iPad. How can I get this new algorythm perminantly stored onto the H9 hardware so I can use it if I don’t have the iPad with me?
July 11, 2016 at 4:40 pm #143798
floresp640
MemberEventide StaffThe Algorithm you purchased should be permanently stored into the H9 as soon as you buy it. You should be able to find it by pressing the presets button and scrolling through the different algorithms in your H9. Another thing you could do to more easily access a algorithm that you like is to save your preset into one of the banks in the H9 and you will be able to acess that specific preset easily.
July 12, 2016 at 12:51 am #143803
Houman
MemberThanks for the info.
In the H9 hardware I have 99 pre-sets (1 to 99), when I use the purchased algorythm via the iPad the diplay number shows “0” on the H9. However, I can not access the number “0” directly from the hardware, it will only display when I activate the algorythm from the iPad. Do you know where its supposted to be stored on the H9 hardware?
July 12, 2016 at 1:07 am #143804
gkellum
ParticipantHouman wrote:In the H9 hardware I have 99 pre-sets (1 to 99), when I use the purchased algorythm via the iPad the diplay number shows "0" on the H9. However, I can not access the number "0" directly from the hardware, it will only display when I activate the algorythm from the iPad. Do you know where its supposted to be stored on the H9 hardware?
Preset 0 is a special preset. It's explained in the H9 Control manual on the first page. You can find the manual in H9 Control under Settings / Help. You can also read it online here:
https://s3.amazonaws.com/com.eventide.downloads/Product+Manuals/H9ControlManual.pdf
July 12, 2016 at 1:11 am #143805
Houman
MemberGot It!! Thanks!!
So once the purchased algorythm is in the “0” position I can save it by overriding any one of the other 99 presets on the H9 box.I will no longer have access to the one I overrode unless I reset the factory setting. Am I right?
July 12, 2016 at 1:15 am #143806
gkellum
ParticipantHouman wrote:So once the purchased algorythm is in the "0" position I can save it by overriding any one of the other 99 presets on the H9 box.I will no longer have access to the one I overrode unless I reset the factory setting. Am I right?
Yeap. That's how it works.
July 12, 2016 at 1:15 am #143807
Houman
MemberMany Thanks 🙂
