With a timefactor, can you save your own presets in the banks above the 50's. Using a midi controller allows you to get to banks much higher then loaded presets. Also can you re-assign the banks in FactorLib? This would allow you to move the pre-loaded presets to banks higher then the 50's banks and get to then with the midi controller. CAN"T figure this one out!
