self modulating eclipse
Home › Forums › Products › Rackmount › self modulating eclipse
Viewing 5 reply threads
    • #110900
      lionelred
        does anyone know why this is happening.
        It is not connected to midi but even when i create new presets certain perameters self modulate i.e reverb decay
        some of the mod sources bpm are also self modulating?
        i am running v4
        any ideas
      • #124439
          Pretty much any parameter on an Eclipse can be modulated. My guess is that you have some modulation sources connected without knowing it. You could try either a "clear internal memory" UM p.56, or look at each parameter that is being modulated in turn and check its modulation source (see UM p.40-46).
        • #124440
          lionelred
            I cleared internal memory hopefully that will solve it
            thanks
          • #124449
            lionelred
              I cleared the internal memory.
              Made anew preset saved it to internal storage and loaded the program and the problem has come back!??!?!? weird
            • #135354
                Why do you say they are modulating ?
                Are the parameter names underlined ?
                Can you check and see if they have actual modulation sources ?
                Some algorithms have prewired modulation sources to some of the parameters.
              • #135356
                lionelred
                  I think I cracked it, thanks
