Settings always change to same algo on startup
Home › Forums › Products › Stompboxes › Settings always change to same algo on startup
    • #187150
      GratefulDean
        When I power on my H9 it always is active (even if it was disengaged at shutoff) and always on the same preset (#1). How do I change that? I would like it to remain on whatever setting it was on when shut off. Or, at minimum, be off when plugged back in. Or maybe change the preset it defaults to.
        <span style=”font-size: inherit;”>Thanks</span>
      • #187174
        tsternfeld
          This isn’t what should be happening, so it’s likely a hardware issue. Please contact support@eventideaudio.com, and they will assist you in troubleshooting and/or sending the unit in for repair.
