Should I perform an upgrade to my timefactor?
Home › Forums › Products › Stompboxes › Should I perform an upgrade to my timefactor?
    • #115706
      Hi, I have a timefactor pedal, and I installed the eventide direct updater. Attaching what it currently says.
      Basically, I’ve got v5.0.1 installed, but it says 3.5.0 is available. So I don’t understand: why should I install a previous version? Or is it something else?
      Then there’s also a v5.2.0 which is said for H9 Control compatibility, but my pedal till now just worked well with the H9 Control software (I use it for backing up my presets)
      So I really do not understand what and why I should eventually update.
      Could anyone shed some light? Thank you.
    • #153779
        It does sound confusing…
        BUT, if you don't have a clear need to update your unit, leave it alone.
        Updates are a fiddle and take time, and occasionally go wrong.
        It does not sound like you see a need, so, again, leave it alone and just use it !
