solved: H9 Beginner question: Harpeggiator – only SEQUENCE B effects the sound
Home Forums Products Stompboxes solved: H9 Beginner question: Harpeggiator – only SEQUENCE B effects the sound
    • #149995
      mistercharlie
      Kai-vD wrote:
      For example: In preset SPACETREM or DOWNUP or …: SEQUENCE A is not noticeable.
      No matter how much I tweak the ARP MIX or any of the other knobs/sliders: I can only notice SEQUENCE B effecting the sound. SEQUENCE A doesn’t seem to do anything!
      What I’m I doing wrong? Is there any setting for this I am overlooking?
      Is your rig wired correctly? Sounds like you might only be getting half of a stereo signal.
    • #114919
      Kai-vD
      Edt: Solved – I had a mono signal with a stereo connection.
