Sorting algos “By Type” is inconsistent?
Home Forums Products Stompboxes Sorting algos “By Type” is inconsistent?
    • #115270
      In H9 Control “Settings”, I have selected to sort algos on the “Algorithms” screen “By Type”.  With that setting, the first two TimeFactor algos are Digital Delay, and then Vintage Delay.  Then, in the “Presets” screen, I also select “By Type” in the top-left corner, above the left-most column of algos (when view is set to display that column).  But there, the first two algos are Digital Delay, and then Looper.
      This is just one example.  When sorting algos “by type” on both screens, the sorting is different for many algos.  Can that be fixed?  It would be nice if “by type” sorting was consistent across all screens.
    • #151671
      bohan
        Wallower wrote:
        In H9 Control "Settings", I have selected to sort algos on the "Algorithms" screen "By Type".  With that setting, the first two TimeFactor algos are Digital Delay, and then Vintage Delay.  Then, in the "Presets" screen, I also select "By Type" in the top-left corner, above the left-most column of algos (when view is set to display that column).  But there, the first two algos are Digital Delay, and then Looper.
        This is just one example.  When sorting algos "by type" on both screens, the sorting is different for many algos.  Can that be fixed?  It would be nice if "by type" sorting was consistent across all screens.
        Thanks for your feedback. It might be fixed in future updates.
