Space Display Glitch
Home Forums Products Stompboxes Space Display Glitch
Viewing 8 reply threads
    • #111573
      I have a Space stompbox that is a little under 4 months old, never gigged/abused. The system has been updated and it's running the current firmware.
      I have two issues:
      1) Sometimes when I save a preset it completely freezes the stompbox and I have to pull the power cable to be able to use it again.
      2) I have attached a picture of this one. Sometime when it boots up the display is all glitched out and none of the lights come on. It am able to hear the preset that I"m on, so that part works, but I cannot see the preset name nor any of the indicator lights.
      Is anyone else experiencing anything like this?
      [View:http://forum.eventide.com/cs/themes/eventide/utility/:550:0]
    • #125792
        This is probably a power supply issue. If you are not using the one that came with it, please do.
        If you are using the supplied power supply, please contact support@eventide.com
      • #125793
        I am using a Voodoo Labs Pedal Power 4×4 that is designed to work with Eventide pedals. I am plugged into the 12V and 400mA outlet. I don't think the power supply is the issue.
        The supplied power supply has a reputation for failing rather quickly and unpredictably so I would rather not use it. .
      • #136537
        rabiddiabetic13
           you should try the power supply that came with it.  If the problem still exist you will know that it is something else causing the problem, just my two cents.
        • #136540
          Imerkat
            Sometimes when you power up the language gets set to Predator and you can easily select the self-destruct sequence accidently…. do a factory reset you should be fine
          • #136541
            Ha! Yes
            The consequence of Blackhole reverb… it provides a portal for Predator to fly his ship through.
          • #125961
            SoundToyLee
              I have same issue here, I have sent an email to Support@eventide.com and waiting for the reply.
            • #136681
                rabiddiabetic13:
              • #167813
                Eisrael
                  so, i got mine 2 days ago, and started to happen the same issue, does it have a solution? eventide support still not answering me
                  help!
