SPACE – Don’t understand the high decay & low decay settings on HALL reverb
Home › Forums › Products › Stompboxes › SPACE – Don’t understand the high decay & low decay settings on HALL reverb
    • #107931
      Hi
      I understand what the high decay and low decay settings are trying to do on the HALL setting on the space. It modifies the rate at which the low & high reverb frequencies decay. What I don't understand is if I set the decay time to say 2.0 seconds and then I turn the X knob to modify the low decay setting it goes from 0.0 to 5.0. What does this mean? If I turn to it say 3.0 does it mean it takes 3 X the overall reverb decay time of 2.0 seconds  = 6 seconds to fully decay?
      Anyone know?
      Thanks
    • #122257
      Yep, I think you're right!
    • #122258
      wedelich
        Hi tucky,
        Tim's correct, you are right.  If you'll notice those knobs read DCYx1.0, etc.  The "x" is for multiplication.
        Russ
