Home › Forums › Products › Stompboxes › Space – increase the Decays in DualVerb to infinate?
May 17, 2011 at 12:11 pm #107884
Is there any way to increase the decays in DualVerb to Infinate in a future software update?
This would improve the HotSwitch Freeze and allow for drones etc.
Others on TGP were discussing this and I said I would raise the question.
Cheers
May 17, 2011 at 4:47 pm #122128
We've been thinking about doing this already, so consider it added to the list of feature requests for Space updates.
-Russ
May 17, 2011 at 4:56 pm #122129
hey Russ,
thanks for that, much appreciated.
Cheers
Martin
May 17, 2011 at 5:23 pm #122131
Awesome! So this would be much like the EH Freeze pedal? (One more reason to save up for a Space I guess.)
May 17, 2011 at 5:29 pm #133407
guitarlesson:
similar to the Freeze, but sounds different in a good way IMHO.
May 17, 2011 at 6:03 pm #122132
wedelich:
-Russ
Hey Russ,
also more extreme modulation options is conversation I was having over at TGP, so allowing the modulation to go further to get some whackier sounds.
Cheers
Martin
May 17, 2011 at 8:32 pm #133412
+1
May 18, 2011 at 1:26 am #122142
Another +1 for some more modulation options – a selection of modulation waveforms similar to the ones available for TremoloVerb for all of the modulated reverb algos would be great, i.e. sine, triangle, peak, ramp, square, etc.
May 19, 2011 at 8:41 pm #122159
+1
June 1, 2011 at 3:00 pm #122219
I'm using SPACE in such a way that I have the mix knob assigned to an expression pedal so I can fade the effect in and out as I play. One downside to this is that going ccw on the knob cuts both the wet signal and the trails, so as I move the pedal back to toe-up, the reverb unnaturally decays down similar to something like a post effect, master level control.
Would it be possible to have an option where the reverb trails as the mix knob is adjusted, so that the mix knob is effectively adjusting only the input signal level into the reverb engine? I imagine the wet (and possibly dry) level would still have to be configurable as well…somewhere.
Thanks for listening.
June 1, 2011 at 4:14 pm #133462
Possibly in the distant future. For now you could do what you are talking about by putting a volume pedal before Space, in a parallel effects loop.
