Space pedal – can’t set decay to Infinite
Home Forums Products Stompboxes Space pedal – can’t set decay to Infinite
    • #175438
      iVoltage
      Hi all,
      Just picked up an Eventide Space and was super excited to try using the hotswitch for infinite decay, but I was disappointed when I turned the decay knob up only to find it maxed out at 50 seconds 🙁 this was on the hall setting. I also tried with the Dual Reverb setting and on that one each reverb’s decay again only went to 50 seconds. Am I missing something obvious? Do I need a firmware update? I attached an image from the manual that states you can set the decay knobs to infinite. Any help is appreciated!
    • #175441
      Freeze & Infinite were added to Space with the 4.0.0(6) update.  So check your current version, and if it’s not, update it with Eventide Device Manager.
      Here are a few pointers, with the breakdown of how those parameters should work, a little further down in the thread:
      https://www.eventideaudio.com/forums/topic/freeze-function-like-eh-superego-on-h9/#post-147832
