Space pedal midi input clock enable question
Home Forums Products Stompboxes Space pedal midi input clock enable question
    • #116425
      I’m trying to set the midi input clock enable to “on”, but when I do, the display flashes. When set to “off” it does not flash. I’ve rtfm’ed several times, and found no reference to the flashing; it must be a setting incompatibility or something similar, but I can’t figure it out. Probably something obvious. :/
      I read the first 23 pages of the Space forum, but found nothing on this specifically.
      Any ideas? Thanks in advance.
    • #157531
      joecozzi
        All Factor series pedals flash when MIDI CLK is set to ON. The blinking indicates that the ‘Factor pedal isn’t seeing any MIDI clock input. When it recognizes the timing pulse, the blinking stops immediately.
      • #157532
        Ah, I see. I will check this out tomorrow; thanks very much for your prompt and helpful reply!
        I’m re-sorting a synth midi rig after adding a MidiHub, so some things/midi routings in the rig are a bit different now.
