SPACE SPILL QUESTION
Home Forums Products Stompboxes SPACE SPILL QUESTION
Viewing 3 reply threads
    • #109310
      fmanfredi76
        From the Space user guide: With Spill enabled the ‘tail’ of the previous Preset effect ‘spills’
        over when a new Preset is loaded. That means that Spill option is available only when the effect is engaged, and not in bypass mode. I think it would be a really nice feature to have spill smoothly fading even disengaging the pedal, especially with long decay reverbs like shimmer, modechoverb, dual verb, blackhole ecc. Maybe I'm missing something?
      • #124028
        rabiddiabetic13
          set up the bypass mode to DSP+FX.  Spillover will occur when you put space into bypass.
        • #124029
          fmanfredi76
            Thank you! Maybe you can help me to solve another – I hope less dumb – issue. When I switch preset via MIDI PC messages, sometimes a short but noticeably (and annoying) increase of signal volume occurs. Is this the normal behavior of the unit? Thank you again.
          • #135023
            rabiddiabetic13
              You're welcome glad to help, Sorry I don't use MIDI for PC messages, but I remember seeing a post about this problem recently.  Check it out for a possible answer.
