Space True Bypass?
Home Forums Products Stompboxes Space True Bypass?
Viewing 3 reply threads
    • #112420
      promero85
        Hi I am trying to run a Fuzz Factory after my Eventide Space and realized that the sound and oscillations are very different between the reverb on/off (sound properly when is off). I am not running any compressors or buffers before the Space that could be affecting the FF. Do you know if the Space is on have any buffer or something that could be afecting the FF?
      • #127632
        Yes.
        You need to set the "Bypass" type to "Relay".
      • #138556
        promero85
          I tried that option and it was the same. I think there is buffer active when I engage the pedal even with relay bypass.
        • #138557
            If it is in relay bypass, the Space is essentially not there.
            Make sure you can hear the relays click when you go in and out.
