Home › Forums › Products › Stompboxes › Space’s omnipressor
September 24, 2012 at 4:35 pm #109135
NikosGuitar
MemberHello!
I want to ask you a big favor!
I never had a compressor before,so i have no idea on how to make this that i want…
i used to play classical guitar with fingernails,but know i have cut them(the nails) because i spend more time practising 8-finger tapping and the nails didn't allow me to tap…
But there are times that i want to play with my fingers and cause of the flesh the tone is so muddy,low and without the "bright" tone that the nails produce!
Can you please suggest me some setting that will help that that i am looking for?
Thanks,
Nikos
September 27, 2012 at 8:15 pm #123856
NikosGuitar
MemberAny help,please…
i want to have the same level-brightness with my fingers as with the pick!
I had never a compressor…any advice will be much appreciated!
Thanks
September 27, 2012 at 9:58 pm #123858
ModeratorEventide Staff"cause of the flesh the tone is so muddy,low and without the "bright" tone that the nails produce"
Sounds like you understand the problem. Some kind of pick … ?
September 27, 2012 at 11:38 pm #123859
NikosGuitar
MemberHello mr.Rose
Pleased to meet you!…i am aware-fun of your work with ELP!!!
back to subject:i don't want to grow up my fingernails again…i want to use the fingerstyle blended with 8-finger tapping!that's why i cut them off…and i want to know if it is possible to compress them to the same level?
Thanks,
September 28, 2012 at 3:21 pm #123860
wedelich
ModeratorEventide StaffHi NikosGuitar,
Practically, I would recommend fingerpicking as close the bridge as possible. Signal-Processing-wise, I would recommend using the Ominpressor with ratio of around 3, release around 0.1 – 0.2 Secs and attack probably greater than 0.01 Secs. You should also move the Contour all the way left for a Feed-foward compressor. and you'll probably want to brighten up the sound by boosting the High EQ knob. You'll have to set the Threshold based on your guitar and use the Output Gain in Space for make up gain (or some external boost pedal post Space).
The idea with this being you want the compressor to only act after the initial attack, bringing down the gain of the note release and decay, but keeping the attack louder. The make-up gain will then bring the whole signal back up.
October 3, 2012 at 11:44 am #123867
NikosGuitar
MemberThank you a lot mr.Wedelich!!!
Your suggestion save me-help me a lot!!!
Thanks,
Nikos
