Specular Reverb 2 with H9 max
Home › Forums › Products › Stompboxes › Specular Reverb 2 with H9 max
    • #114587
      Reinando
        Hi everyone,
        I’m fascinated by the Specular Reverb Vers. 2 of GFI System, especially by the shimmer effects (pitch-shifted effects) !
        I think it should be possible to create these sounds with the H9 max, which I own.
        Does someone have an idea how to realize this?
        I would be very happy about it!smiley
        Thanks a lot in advance!!
        Best,
        Reinando, Germany
      • #148347
          I don’t see any Specular Reverb modes that you could not emulate in the H9.  For the shimmer mode, I would use … the Shimmer algorithm.  There are other ways to do this in an H9 Max, but this one is the most straightforward.  Here’s an explanation of the Shimmer algorithm by parameter:
          https://www.eventideaudio.com/products/algorithms/shimmer
          I found an earlier thread with some Shimmer parameter detail from Eventide, and myself.  I put together a little demo program that might help you along.  If you get stuck on any specific points, reply back.
          https://www.eventideaudio.com/community/forum/stompboxes/h9-shimmer-pitch-decay-etc
