spring_dispersion broken rather badly?
Home › Forums › Products › Vsig and Preset Development › spring_dispersion broken rather badly?
    • #163434
      studionebula
        I’m getting back into VSig after a hiatus. I thought I’d give the spring_dispersion block a try, based on its intriguing description, but it seems to be completely broken. Including it in an algorithm uploaded to FX Chain 1 Slot 1 seems to confuse my H9000 so badly that only a power cycle will restore it to operation. The input LEDs are still active but no sound comes out of the algorithm, and even trying to replace the FX chain with a preset seemingly has no effect. I’m running at 48KHz with ADAT I/O, no USB audio connection. I’m running the current versions (as of 4/13/22) of the H9000 firmware and VSig.
      • #163460
        John Baylies
          The spring_dispersion module crashes my H9000 as well. Use the dispfilt module instead. It’s quite similar.
        • #163547
          studionebula
            Thanks for the confirmation and the pointer to dispfilt. It adds an interesting sort of watery sound to attack transients.
