Strymon Conduit and Eventide H9: MIDI program change message with a Strymon TRS to MIDI 5pin cable does not work. H9 does not respond. H9 midi channel set to channel 4. Pedalboard: BOSS ES-5 – Strymon Conduit – Eventide H9. Does anyone know the solution?
Is the H9 System – Output set to THRU? (There may be a similar setting in the Strymon – I don’t own any). <p style=”text-align: left;”>Just from what I’ve read, I believe they both use the MIDI Type A “standard” TRS to DIN configuration.</p>
