Suggestion: performance banking (plus eq)
Home › Forums › Products › Stompboxes › Suggestion: performance banking (plus eq)
Viewing 3 reply threads
    • #188205
      Mooncat
        Could this not be added DD-500 style? IE when in performance mode, simultaneously pressing the middle and right footswitches would bank up, and the pressing the middle and left footswitches would bank down? Would save an aux switch and would really open up the performing functionality of the unit.
        Also, any chance of a global parametric eq? In my band I usually need a 2 band EQ, one to make a cut to carve out some space for the bass, and one as a boost for me to cut through. Having this as a global option would be useful, and save an algorithm slot.
      • #188208
          Are you talking about perform mode or bank mode?
          A global EQ is a great idea and something we’d like to add in a future update. Where you prefer the EQ to be in the signal path?
        • #188209
          Mooncat
            I mean perform mode. I’d like to be able to leave the H90 in perform mode all the time, but still be able to switch between programs with one motion, IE the simultaneous press of two footswitches with my foot. This means you get the best of all worlds.
            So to clarify, if I was in perform mode, the 3 footswitches individually would be controlling things like bypass or parameters, but pressing the middle/right simultaneously would switch to the next highest program, and pressing middle/left simultaneously would switch to the previous program.
            An option to place it pre or post program, would be great.
          • #188210
            Mooncat
              “An option to place it pre or post program, would be great.”
              <p style=”text-align: left;”>Meaning the EQ here</p>
