Tap Tempo Sync using 2 H9’s
Home › Forums › Products › Stompboxes › Tap Tempo Sync using 2 H9’s
    • #114268
      kaiapollo
        I am having an issue with Tap Tempo sync with 2 H9’s. My setup is as follows:
        Master:
        Midi Clock Settings
        –          Enable Midi  Input Clock  —  NO
        –          Enable Midi Clock Filter – NO
        –          Enable Midi  Output Clock  —  YES
        Midi Output Mode =Transmit
        Slave:
        –          Enable Midi  Input Clock  —  YES
        –          Enable Midi  Output Clock  —  NO
        Midi Output Mode =Thru
        Midi Cable on the Master is Plugged into the Output and to the Input on the Slave.
        When I use the Tap Tempo on the Master it changes the Tempo on the Master, but the Slave stays at the tempo that it was previously set for. What am I missing?
      • #146807
        kaiapollo
          OK anyone who reads this question, there must have been some other setting interfering because I reset the unit to factory defaults then resetthe midi clock  and output setting and it is working as it should
