Tempo mode H90
Home Forums Products Stompboxes Tempo mode H90
    • #198959
      leafbelly
        Hello everyone,
        I work exclusively in time increments for all parameters for delay, reverb, LFO, etc. in my studio and don’t use MIDI (at least for the H90). And, sorry for asking if it’s been answered, but I looked everywhere: Can I set a global preference in the H90 Control App so that tempo mode is off by default when creating new programs? Currently, I have to manually disable tempo mode for every single program I build from scratch. Can this be changed?
        Thanks SO much for any help. I’m having a blast with my H90. Best. Pedal. Ever.
        Don
      • #199427
          Hi, glad to hear you’re enjoying the H90!
          There is no global setting for Tempo Mode to always be off, but we may be able to add something like that to a future update.
          If you are building a Program from scratch, you can start with an INIT Program which is made out of 2 Thru Presets. If you replace either of those Presets, then certain Algorithm’s Presets will have Tempo Mode on, while others won’t.
          For example, the “Band Delay” preset has Tempo Mode on, while “Guitars In Space” has Tempo Mode off.
          You could save some custom default Presets with Tempo Mode off for some of the Algorithms you are using most frequently and that may improve the workflow for you.
        • #199428
          leafbelly
            Great. Thanks for the info!
            A global preference for tempo would always be nice, but of course not necessary. I just wanted to ask in case I was just missing it somewhere.
            Much appreciated!
            DW
