time factor aux switches
Home › Forums › Products › Stompboxes › time factor aux switches
Viewing 3 reply threads
    • #105482
      hi,
      just wondered if the aux switches can be used as a mini midii pedal in as much as selecting patches?
      i see you have bank up down but cant see how to select a/b patch?
      cheers.
    • #117206
      forgot to add im using it in the amps loop so its sat ontop just using remote control from a midi controller.trying to cut down on gear!
    • #117211
      achaput
        If you assign the aux switches to FS1, FS2, and FS3, then while the Stompbox is in Play Mode the three aux switches will have Bank Mode functionality (Bank_Preset1, Bank_Preset2, and Bank Up. The first two aux switches will transmit MIDI Program Change when selecting presets just as the onboard footswitches do.
        Alan
      • #117218
        seem to work a treat and of course you can limit the number of bank changes,many thanks!
        is this in the manual?
