time factor clip
Home Forums Products Stompboxes time factor clip
Viewing 0 reply threads
    • #108121
       i've a problem  with timefactor:
      -switching    between   two different  presets in the same bank ( also if i mute  my guitar-most with the reverse delay)  there's  a hardy clip  (That is not always the case)  .
      the preset  1 must be active  during  the  switch to  the  preset 2.
      the spill  must be set -on (if  i switch the spill off  there is not  a problem )
      -somethime  (spill on)  the delay have some problem with  the sound (for example the delay stop or change time -not the time of the new preset- )
