Time factor stereo out to mono?
Home Forums Products Stompboxes Time factor stereo out to mono?
Viewing 3 reply threads
    • #116283
      So I see that you can take a mono input into the time factor and it will output stereo.
      What I want to do is run both delays in a mono chain.  I know that you can do the in A/out A, then in B/out B, but the 2nd delay is affected which I don’t want if possible.
      If I go mono in to A do I have access to the B effect?  I would like to do mono input A and then output both A and B, then combine them into a mono output back into my chain.
      Possible?
      thanks
    • #156787
      joecozzi
        Why don’t you just go into the TimeFactor mono and come out mono? It basically does the same thing you want to do.
      • #156789
        So mono input has access to both A and B delays, and they output mono as well?
      • #156790
        joecozzi
          Yes. Parameters like Delay Mix allow you to adjust the balance between both delays.
