Time Factor : unwanted chorus when “no delay”
Home Forums Products Stompboxes Time Factor : unwanted chorus when “no delay”
Viewing 0 reply threads
    • #159264
      nicklaus_rohrbach
        Hi !
        I’m using my Time Factor as a dual parallel delay processor for my guitar pedal board. I’ve got two pedal paths, A and B, and each has one specific delay setting at the end, channel A and B in the Time Factor. (delay mix 10:10, mid position)
        It’s working fine except for one thing : If I want effect line A to have no delay, and Effect line B to have a hige delay, I set the time to minimum on channel A, it reads “no delay”, which exactly what I want, but I have a chorus/phase effect. As if I was hearing direct signal AND a few milliseconds delayed signal.
        Does any one know if it’s possible to have a true clear channel one side and a big delay channel on the other?
        Thanks a lot dudes !
        P.S. If the pre/post routing was a “preset” setting instead of a “global” one,that should do the trick…
