Home › Forums › Products › Stompboxes › TIME IN MICROPITCH PEDAL
to adjust the time delay in Micropitch pedal is only in BPM?
It is possible in milliseconds?
I don’t find in the quick manual…
Thank you
If the pedal is in Tap Time mode, the delay time will be in mS from 0-3 seconds.
If the pedal is in Tap Tempo mode, the delay time will be note divisions that are synced to the tap tempo.
If you look at the last page of the QRG that may help you understand how it works: https://cdn.eventideaudio.com/uploads/2021/10/MicroPitchDelay-QRG-Web.pdf
You can use the H90 Control app to adjust the pedal parameters and this will tell you the exact delay time values being set: https://www.eventideaudio.com/downloads/?product=H90+Control
Let me know if you have any questions.
Ok,
i have a Blackhole pedal and only use EDM…
If it’s possible to adjust the time in ms with the H90 Control, it’s ok for me.
I’m thinking about to byt it.
Another question:
The products to have a ping-pong delays are only the TIMEFACTOR and the H90?
Many thanks
You’re welcome.
All of the dot9 pedals can be used with H90 Control.
MicroPitch and Ultratap can both achieve ping-pong style hard panned delays if you like the smaller stompbox style.
TimeFactor, H9, or H90 will all give me many more delay options in a bigger box.
