Home › Forums › Products › Stompboxes › timefactor and ableton
July 5, 2012 at 2:42 am #108908
how would i go about using timefactor through ableton? ive tried to configure it about im getting no audio?
July 5, 2012 at 3:15 pm #123617
are you trying yo configure timefactor as your audio interface or just trying to use it in a FX loop ?
July 5, 2012 at 3:16 pm #123618
Not sure what you are expecting it to do.
July 8, 2012 at 9:26 am #123631
Just in fx loop
July 9, 2012 at 5:36 pm #123636
Can you tell us a bit more about your setup? It would be particularly useful to know what your signal chain is, what audio interface you are using, and how you're currently trying to use the TimeFactor.
July 10, 2012 at 3:04 am #123638
I have a xone 92, native instruments audio 10, traktor pro 2, ableton live 8 and MacBook pro.
I want to use the timefactor effects in sync with the audio from either traktor or ableton.
July 10, 2012 at 7:02 pm #134674
In that case, you should be able to just put the TimeFactor in one of the aux send/returns on the NI Pro 2 or the A&H Xone, depending on how you have Ableton configured and which device you want controlling the TimeFactor's levels. To synchronize your TimeFactor with Ableton, just connect a MIDI cable from the MIDI Out of the NI Pro 2 to the MIDI In on the Timefactor.
