TimeFactor feature request – pre-delay volume/input volume
Home Forums Products Stompboxes TimeFactor feature request – pre-delay volume/input volume
    • #107721
      Can the input volume or pre-delay volume be made into a parameter that the expression pedal can control?
      As it is, if I want to have an expression pedal, AND do delay volume swells, I would need two volume/expression pedals.  If the timefactor could allow control of an input volume or pre-delay volume, then this would eliminate that need.
    • #123807
      Etienne
        Hello, sorry not really an answer, but I have the same request, I d'like to swell the main volume (as well the feedback value) using the expression pedal.
        Do you find an answer?
        Thanks
      • #123815
        ndeshpande
          For reference: http://forum.eventide.com/cs/forums/p/8043/36179.aspx#36179
          "Hi,
          At this time, you can't control the input gain on the TimeFactor. Although this is unsupported, my suggestion would be to get a splitter/mixer or true bypass loop, and then put a volume pedal in front of the TimeFactor but after your signal has [been] split. "
          Thanks,
          Nikhil
