hi,
i love the tf. later i'll et into using the express i tried when i first went through it.
but for now, and to get it into use, i need someone to advise me on how to get two great sounds side by side.
i have a boss dd3 analogman mod…sounds gat on long delays SO i need tf to do that on one side but with tail continuing when cut off i do know how to set that default bypass.
i think i want ducked delays–does ducked or does any tf mode have a dynamic type delay, like a tc2290 where play attack (guitar) brings it in/out?
i'll set up the expression pedal to add feedback to the long delay.
then on other side–two available delays right?–so i need that on one side and slapback on the other.
therefore, my starting point will be your standard guitarist two delays setup…one for slap (albeit you might just call that side shorter delays including slap) one for effect.
i want these programmed in/saved.
Show More...can someone help set this up?
then i'll toss the dd2 back in to do what it does. (or not.)
