Home › Forums › Products › Stompboxes › timefactor level difference???
November 3, 2012 at 9:53 pm #109257
this is quite strange, since the last update, engaging my TF is increasing the overall level of my signal by an amount which makes it quite unusable live… anyone experiencing this?? It does it on every bypass mode, and no other pedals are connected. Different guitars, different amps, all the same problem.
Any advice anyone?
November 5, 2012 at 5:10 pm #123966
Check the guitar/line level switches.
November 5, 2012 at 6:13 pm #123968
thanks for your input, but I'm afraid it's less obvious then that. switches are As they should be.
November 5, 2012 at 6:16 pm #123969
If it does this on relay bypass mode, it really is not our pedal. My guess is that it is something at your end. Sorry.
November 5, 2012 at 8:10 pm #123970
thanks for your reply,
Turns out it was the pedal… for reference: in an earlier SW-update (which i had skipped), an output volume control was incorporated (hold left button for 2sec to see it, change with program knob). So i checked that, and it turns out the output volume was set at +9dB. I'm pretty sure I didn't change that setting previously, I litteraly updated the pedal and plugged it in straight away. The devil is in the details…
(why would it occurring in relay mode rule out the pedal as being the cause of the problem btw? that doesn't make sense to me..esp after I had swapped out every bit of my chain)
oh well guess the MemoryMan goes back in the closet….
best regards -
November 5, 2012 at 8:24 pm #134982
In relay bypass mode, the input is essentially directly connected to the output, and the pedal is to all intents and purposes out of the circuit.
But, glad you got it working ..
