Timefactor – ‘loop mode’ only – questions
Home › Forums › Products › Stompboxes › Timefactor – ‘loop mode’ only – questions
    • #109179
      I'm considering getting a Timefactor, and only using it in 'loop mode'.  I would specifically need it to do the following:
      1. Allow the user to easily (and reliably) create loops synced to MIDI clock (from a drum machine)
      2. Also allow a user to easily create reverse loops that are synced to MIDI clock
      3. Be able to split the loop-mode output to 2 channels, so one channel gets 100% of the loop and the other channel gets 100% of the dry signal.
      Most info. and videos on the Timefactor focus on the delay, and I haven't been able to find answers on these specific loop-mode questions.  Any input will be appreciated!
      – Jim
    • #123882
        Sorry – no reverse loops at present.
        If all you want is a looper, a TF may not be your best choice – you'll be missing out on most of what it can do.
      • #123883
        Okay, thanks for the info. I was thinking the reverse delay effect could be applied to the loop.  So this — plus no built-in reverse loop option — makes it clear to me.
        Regards,
        Jim
