Timefactor MIDI workflow problem
Home › Forums › Products › Stompboxes › Timefactor MIDI workflow problem
Viewing 0 reply threads
    • #114105
      I am controlling a Timefactor with a DisasterArea DPC-5 Gen3. The Timefactor kills trailing delay when you switch programs and takes a noticiable amount of time to engage the next program, which I assume there is just the way it is. The problem I have is that switching from one patch on my DPC-5 to another (same midi setting on the Timefactor) I experience the same issue (killing the delay for a second or so). Is there a way to prevent a midi message that sets the Timefactor to the exact same setting from ‘resetting’ the algorithm as if no midi change was received in the first place?
      Thanks in advance for any advice on this issue!
      If anyone else has experienced this issue and has come up with a decent work around, I’d love to hear!
