Timefactor /modfactor midi
Home Forums Products Stompboxes Timefactor /modfactor midi
    • #111132
      serge20261
        I purchased a rack gizmo ,ground control pro,and have the modfactor and timefactor,waiting on the space.
        I have one midi cable going from the rack gizmo midi out to the time factor midi in,and from the timefactor midi thru to modfactor midi in.
        The time factor changes patches but the modfactor won't
        If I reversed the wiring eg rack gizmo out to modfactor midi in the modfactor will change preset but no the timefactor.
        I have tried several midi cables without success
        The midi devices are on different channels
        Am I missing something,or haven't set something up
      • #124880
        gkellum
        • #124972
          With the Ground Control Pro, you will need to assign each device on the pedal board. Then you will need to program each setting for each unit on the GCP. I control a Timefactor and Pitchfactor in the exact same configuration as you describe with remarkable success.
