Timefactor not found?
Home Forums Products Stompboxes Timefactor not found?
    • #107561
      spydog
        Sorry if this is a common issue…I searched the forums and couldn't find any info.
        So, I'm trying to update the firmware, and when I connected the Timefactor to my PC via USB, it didn't appear to "install" correctly.  In fact, when I go to Start>Devices and Printers, the Timefactor shows up as a device, but with a yellow exclamation triangle symbol meaning that something isn't quite right.  The windows troubleshooter wants me to reinstall the driver, but that process doesn't seem to do anything.
        When I try to run the UPdater, it can not find my Timefactor.  I'm running Windows 7 64-bit,.  I hope that's not the issue.
        I checked to make sure that the Midi clock was set to off.
      • #121405
          Yhis is the same problem that a number of our other people have encountered.
          http://forum.eventide.com/cs/forums/p/6156/30340.aspx#30340
          I'm afraid my current best advice is to use an XP box or a Mac – this is a rare issue with a very small number of units and XP/Vista – you got lucky – sorry.
