timefactor settings with stereo amps?
Home Forums Products Stompboxes timefactor settings with stereo amps?
    • #107599
      forgivenick
      Can I get some suggestions for how to setup the timefactor to output to my dual amp setup? I like ping ponging delays a lot, but also the wet dry thing, just not sure what other people use. Would like to have more options for panning.
    • #121478
      timothyhill
      Depends on what you want to do, how you're using two amps, and if the amps have effects loops (and if so, series or parallel). Almost anything's valid as long as the levels are set correctly (per user manual). The most important thing is that it sounds good to you.
      Guitar >> TF In A >> TF Out A >> Amp 1
      ………………………TF Out B >> Amp 2
      Guitar >> Amp 1 >> FX Send 1>> TF In A >> FX Return 1
      ……..>> Amp 2 >> FX Send 2>> TF In B >> FX Return 2
      Guitar >> Amp 1 >> FX Send 1 >> TF In A >> TF Out A >> FX Return 1
      ……………………………………………..>> TF Out B >> FX Return 2
      Guitar >> Amp 1 >> Direct Out 1 >> TF In A >> TF Out A >> Amp 2
      Just a few examples of setups I've used.
    • #121479
      forgivenick
      Thanks for the reply Tim.
      I have a superchamp xd & blues junior, so fx loops aren't possible.
      Are there settings to make both amps sound the same (not just wet on one, dry on the other) or ping pong smoothly.
