Home › Forums › Products › Stompboxes › Timefactor + Space MIDI clocks
- This topic has 6 replies, 2 voices, and was last updated 3 years, 3 months ago by
brock.
November 21, 2022 at 6:12 pm #166922
Greetings.
I’d like to know if it’s possible to have a Timefactor to send its tempo/bpm via MIDI into a Space, and then have the Space send that same clock out via MIDI into another device which can accept MIDI clock sync?
Has anyone ever done this, and if so, can you point me in the right direction please?
Thank you. -
November 22, 2022 at 8:17 am #166926
If all you’re after is MIDI Clock sync, then you don’t have to be concerned about MIDI Channels, Program or Control Change system settings. Otherwise, it gets more involved. I’m sure Joe has some slick videos up on the subject, but here is the basic layout:
TimeFactor -> MIDI cable from OUT/THRU to Space MIDI IN
- System settings – MIDI:
- [OUTPUT] XMT
- MIDICLK OUT – ON
SPACE -> MIDI cable from OUT/THRU to 3rd Device MIDI IN (set device to receive MIDI Clock)
- [OUTPUT] THRU
- MIDICLK IN – ON
3rd device -> set device to receive MIDI Clock
November 22, 2022 at 9:51 am #166929
If all you’re after is MIDI Clock sync, then you don’t have to be concerned about MIDI Channels, Program or Control Change system settings. Otherwise, it gets more involved. I’m sure Joe has some slick videos up on the subject, but here is the basic layout: TimeFactor -> MIDI cable from OUT/THRU to Space MIDI IN
- [OUTPUT] XMT
- MIDICLK OUT – ON
- [OUTPUT] THRU
- MIDICLK IN – ON
Thanks, I’ve set it up like you wrote. This gets the clock correctly to the third device, but the Space freezes in the process and I can’t turn it on anymore.
It only starts responding again when I unplug the MIDI cable.
November 22, 2022 at 10:15 am #166930
I think we just went beyond my remote diagnostics capability. Your TimeFactor & Space are both updated to the latest versions? All I can think of is that perhaps Space’ MIDICLK OUT is also set to ON as well (default is OFF, though).
I guess you could try both devices with MIDICLK OUT: ON, and set the Space [OUTPUT] to THRU + C, as a pure diagnostic test.
November 22, 2022 at 10:35 am #166933
Okay I’ve tried a couple of things, and it seems like a hardware issue of some sort.
Here’s how I connected it:
Timefactor MIDI OUT –> Space MIDI IN
Space MIDI OUT –> external-device MIDI INI have the Timefactor sending the MIDI clock, and the Space set to receive the clock and also send the MIDI it receives through.
My external device sets the clock correctly when I input it through the Tap Tempo on the Timefactor, but funnily enough the Space
freezes in the process. And I found out that I can unfreeze the Space when I unplug the MIDI cable from the Timefactor –> Space
connection and then the BPM is set correctly on the Space as well. At the moment the Space freezes, I cannot even use the footswitch
for bypassing it.I can repeatedly make this happen by plugging the cable in, setting the tempo via Timefactor Tap Tempo, and unplugging the cable.
November 22, 2022 at 12:30 pm #166949
Update:
It turns out it works normally if I make the Space the clock master and have the MIDI chain as: Space –> Timefactor –> external. Weird.
November 22, 2022 at 12:31 pm #166950
Good to hear. Sometimes it’s the little things … gremlins.
