Home › Forums › Products › Stompboxes › TimeFactor Spillover and DSP+DLY Bypass; 100% Dry as bypass option
August 27, 2008 at 11:27 pm #105801
Hi Guys, hope you can help the newb get a grasp on all this.
OK, I'm just trying to understand the difference between the Spillover and DSP+DLY Bypass, because I'm incapable of achieving my expected result, and I figure my ignorance is playing a factor in it!
If I undestand correctly, DSP+DLY Bypass option would allow for a spillover when the unit is bypassed/inactive, and Spill=ON would allow for a spillover when the unit is active and a preset change occurs. euh … right?! 🙂
On another note, I've found myself creating a dummy preset (100% dry) in order to avoid stepping all over the place when a program change message is sent via MIDI (as a temporary workaround .. I hope, as I read that the only way to achieve the BYPASS was through CC messages). Is this the only way of faking a bypass by sending one message (program change) from my fcb1010 (one tap)?
OK, back to the Spillover and DSP+DLY Bypass issue. Well, in fact, there doesn't seem to be an issue with the Bypass option, it's great, but the SPILL doesn't seem to work at all.
Let's say I use preset 1:1 as my dummy 100% dry preset for patches that contain no delay.
When switching from a preset which contains delay (e.g. 1:2) to my preset that doesn't (i.e 1:1), There is no SPILL whatsoever, cuts offs competely at the time the preset change occurs. Also, when changing from a preset (e.g. 2:1) to another that isn't my fake bypass (e.g. 1:2) the trail seems to pickup the new preset (e.g. 1:2) and not its previous preset (2:1). Is this making sense? Is this the expected behaviour?!Thanks for you help!! Much appreciated.
September 23, 2008 at 1:18 am #117875
i tried making a dry patch on my modfactor, and there was a noticable difference in the tone, weird.
