Timefactor Tap Tempo Problem
Home Forums Products Stompboxes Timefactor Tap Tempo Problem
Viewing 6 reply threads
    • #107398
      onurbek
        Hello everybody. I have a disappointing problem with my Timefactor.
        The unit does not respond to tap tempo signals properly. I recently updated the software, but it still does not respond to tap tempo signals both from the on board switch and from an aux switch. It does respond by flashing the little tempo led according to the tapped tempo and does change the delay time in milliseconds, however it won't change the tempo in 'note terms' (1/4, 1/8, 1/32 etc). It used to work normally, but the current situation is of a big problem for me.
        What do you suggest? Thanks in advance.
      • #121038
        madmac
          I would try pushing the encoder button.  It sounds like you have switched off the tempo mode.  You can either have it display in ms or subdivision note values i.e. 1/8, 1/4 ect
        • #121039
          onurbek
            Thanks for the reply. But I know… Of course I tried that.
            The thing is, when I'm in the tempo mode the tap tempo switches send the tempo signal but my Timefactor does not respond by changing the tempo in BPM terms. In other words, say the unit is in the tempo mode and the current tempo is 120 BPM as indicated on the display. I tap a tempo of 80 BPM, the little tempo led flashes in 80 BPM while I am tapping the tempo, but the unit does not change the tempo to 80 BPM and the little led keeps flashing at 120 BPM again.
            However, it does change the tempo in milliseconds when I am not in the tempo mode.
          • #132191
              onurbek:
              At what point does the little led change back to 120 BPM ? If this is when youn next load a preset you need to check the Preset/Global tempo setting – see User Manual.
            • #132194
              onurbek
                Thanks. The little led changes back to 120 BPM as soon as I stop tapping the tempo. So it is not when I load another preset. I appreciate your answers, but believe me I know how to use the unit and there is something wrong in the unit. I checked myself for human error again and again in different days, I am pretty sure I am not missing something because of not knowing how to use the thing or my mind being busy/sleepy etc  🙂 I am puzzled
              • #132201
                  Do you have a MIDIclock connected ? Try disconnecting all MIDI/USB cables (if any) and see if it makes a difference. Also, make sure MIDIclock in is not enabled on the MIDI system menu – if it is, it may overrule the Tap.
                  I really can't think of anything the unit would do which would have the results you describe, so am disinclined to think it is a fault. But, anything is possible – let's just rule out other things first.
                • #132207
                  onurbek
                    Thank you very much nickrose! 😀 I realized that MIDIclock was enabled somehow and I never knew it was there 🙂 As you said, it was overruling the tap. Problem is solved now.
