Timefactor tap tempo problem
Home › Forums › Products › Stompboxes › Timefactor tap tempo problem
Viewing 6 reply threads
    • #108743
      Found this out tonight at rehearsal, I do not usually use a tap tempo setting.
      Anyway, using my usual delay patch, switch to play mode, change delay time to ¼ and tempo ON, tempo light is flashing. Tapping the tap switch does not change the tempo.
      I have to turn tempo off , tap the tempo again then turn tempo On for it to update the speed.
      I tried the same with one of my delay patches on the Pitchfactor and it works fine.
      Both are v3.0
      Any ideas?
    • #123451
      Anyone?
    • #123453
      ccl117
        Not sure if this will do it, but I was just having similar issues with my TimeFactor. The tap tempo lights would blink in sync with my tap pedal (via MIDI cc commands on my floor controller), but the tempo would not change.  Found out that my MIDI Clock setting on the pedal was turned on, which trumped any tap tempo control for me.  I went into the settings under MIDI CLK and turned it off, now my tap tempo works great.  Hope this helps
      • #134561
        Yes indeed that was it. Works great now thanks.
      • #135058
        Thank you soooo much, my tap tempo hasnt worked for a loonng time and i could never figure it out.
      • #135059
        ccl117
          Sweet!
        • #136250
          igrik3v
            Great! it realy helps, thank you!
