Timefactor tap tempo question
Home Forums Products Stompboxes Timefactor tap tempo question
Viewing 5 reply threads
    • #107384
      infrared72
        I was looking in the Timefactor manual today on some things related to Tap Tempo. When I tap a tempo with my foot, is the assumption that I'm tapping quarter notes?  I didn't see a setting for this in the manual, so I'm assuming it's quarter notes.  I tried searching the forum here to see if someone else posted, but the search thing is giving me thousands of results.
      • #121022
        you can pretty well tap in anything you want and use the tempo's to change it. you can tap in whole's if you really wanted….
        i'm not sure i understand the question really.  i tap in quarters mostly…
      • #121024
        caveman
          The tap is a quarter note, meaning that if you set tempo to eighth notes, and tap at 500ms, you will get repeats every 250ms.
        • #121026
          infrared72
            How is it that I set the tempo to eighth notes or other note values?
          • #132185
            caveman
              Dly Time A or Dly Time B.
            • #123303
              I have problems with this i've sey my presets to watever delay times i need. 8th,quarter sometimes mixed.but i cant't get them to sync with the bass drum when i press the tap. they definitly dont sound in time. is there something i'm doing wrong or am i just not programing it right?? i use it in bank mode when i play live. and use an aux swicth for the tap function.THANKS
